CrankPuley For Neo
kambing69
In terms of performance, durability and price, is there any MAJOR different between methodology & works crank pulley..
Or recommend any brand crank pulley for me~
Yr crank pulley is already oversized and lightened variety.
I am not sure of the specs though talk to Mr Su R3..
---------- Post added at 11:27 AM ---------- 6 hour anti-bump limit - Previous post was at 09:44 AM ----------
Is it?? I though the crankpulley is stock oem one, they only change the Campulley~
Okok il talk to Mr. Su next week~
From what I found out from Dori-Dori's tauke: Works LCP is undersized, which will deliver more power to the wheels , but less power to the battery alternator. He said that the idling voltage will be affected a little bit but when you're revving its stabil.
Mythelogy has a damper and is same size as OEM one therefore it's not as light and peroformance improvements also not that significant. (this is from fellow ZTH member who changed, he said waste his money)
I'm planning to change mine on my CPS also..... I think i will go for Works. So far no major side effects reported so yea.... besides that point that it's about 200 cheaper. Trafic jam rev rev sikit lo. Hehe.
I'm driving a satria neo baseline. Anybody here considered Arospeed? Well, i'm looking at Arospeed LCP...mythelogy kinda pricey but not sure if the whole dampened thingy is worth it.
i'm using dori's LCP for a year now (neo AT).. and went thru major jams some times.. didnt have any issues with the battery being weak or anything related..
rm300++ for the LCP, belting and installation.. since its undersized you cant use the stock crank belting.. dori2 is in hitech park.. their address: Jalan Nilam 1/3, Taman Teknologi Tinggi Subang, 40400 Shah Alam, Selangor, Malaysia. or you can search their name in google maps to know its direct location.. if you take the Ebor exit, you're almost there.. :)
So is the response better after changing and any side effects? My tensioner is squeaking also. Sigh..
yup.. better revving after installing it..
timing belt tensioner? i got it changed earlier this year.. rm260 inclusive of installation at dori2.. before that i asked proton service.. they charge 300++ just the tensioner itself not including installation..
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
