D1RDGP - The Simulator Drifting
sakuraguy
5,000 RPM
Sendai, JAPAN.
D1 Racer Grand Prix is a Drift Racing Simulation with real car physics, actual track(s) and actual d1 drift cars. It is a mod of the car simulation game 'Racer'.
Game is even less buggy now with the following package:
Racer v0.5.3b2 + D1RDGP v1.2 + New Car Low-Res Textures which should give everyone better FPS and be more stable.
D1RGP Official Site: D1 Racer Drift Grand Prix - D1 Drift modification pack for Racer Free Car Simulation
Quick Start Guide
1. Download From Link Below
2. Install/Extract
3. Run
4. Setup Controls
5. Select Machine/Car
6. Play.
Download Links: (Racer v0.5.3b2 + D1RDGP v1.2)
- http://www.racer.nl/download/racer053b5.zip (This platform is required)
- http://perthmods.net/Files/Games/d1rgp_fluent-spec_v1.2.exe (This is the game data)
Cars Included:
- Youichi Imamura - Mazda RX-7 FD, APEXi
- Ken Nomura - Nissan Skyline ER34, BLITZ
- Ken Maeda - Toyota Sprinter Trueno, UP GARAGE
- Toshiki Yoshioka - Toyota Sprinter Trueno, DRoo-PR
- Yuuki Izumida - Nissan 350Z, ORC
- Hiroshi Fukuda - Nissan 180SX, STEREO
- Nobuteru Taniguchi - Nissan S15, HKS
Tracks Included:
- Fernstone (JDM Edition)
Adding More Tracks and Cars:
To Add a track, copy or unzip the folder into:
C:\Games\d1\data\tracks so that you would have a C:\Games\d1\data\tracks\[NAMEOFTRACK] folder.
To Add a Car, copy or unzip the folder into:
C:\Games\d1\data\cars so that you would have a C:\Games\d1\data\cars\[NAMEOFCAR] folder
Then just start up the game and its been added:
D1 Tips:
- Try Yuuki Izumida's 350Z, imo it appears to handle the easiest, and use a gamepad with analog stick
- Don't crash into other car's (Multiplayer) else game might hang/crash.
PROBLEMS ?
Bug Fix (I Found this last nite when playing the game):
If you have issues playing the game... or people joining your multi-player game, see if your CPU is a HyperThread Pentium 4 (2 CPU kinda).
If it is then:
- Run racer.exe
- Once D1 game has loaded, press [CTRL] [ALT] [DEL]
- Task Manager Pops up, in Processes tab, select racer.exe
- Right click on it, click 'Set Affinity'
- Uncheck CPU 1 (thus leaving only CPU 0 checked)
- Close Task Manager
- Play D1/Racer
This works for a lot of games... increases performance amazingly.
Also theirs a tool you can use which writes to the exe to auto use CPU 0. But too much hassle
Firewalls: Port Forward/Allow 25000 & 26000 TCP/UDP i think for multiplayer.
Handy Controls: SHIFT+R (Reset Car Position) & 0,1,2,3,4,5,6,7,8,9 for camera views... Other Controls... Check Racer Official Website...
Corrupt Zip File: The file size should be about 42MB. If you download a file smaller than this, it has been corrupted. Use a download manager and re-download the file to fix this problem.
Can't Connect Through My Port:
Do the "bug fixes" as mentioned above. If the error is occuring in a file with a name similar to this "C:\DOCUME~1\Ben\LOCALS~1\Temp\3602_appcompat.txt", then make sure that you have extracted all files, and are not running it from the ZIP archive. Also try disbaling Anti-virus software - especailly the troublesome ones such as McAffee and Norton.
