can try with industrial grade cable ties. recently a friend of mine did on his ride. Seem to pretty much hold up to the abuse ever since!!
Normal use on daily drive don't need to tie loh......
Not true la. If the brake hose is expanding even daily drive will benefit from it
I believe if done properly it can even prolong the brake cable lifespan...
I think you mean brake hose not cable, anyway mine are already 25 years old and another car 20 years old and still using the original brake hoses....![]()
They don't make parts like they used to la Vr2
, but want to cost down and fill many pocket, rakyat kena....
my diy cable tie brake hose is still doing well...none pop out. 4 years car
Now a day lazy to d.i.y cable tie brake hose.
Old already... Hahaha
Cable tie the hose when they are still on the car is real pain in the A**.....![]()
Yup back also ache... need to take out and reinstall 4 tires after tying... :sleep:
Unless take hose out, cable tie then fit back and same time flush the brake fluid......hhahahhahah![]()
cannot do that la. Need to flex and twist the hose
Im here seeking ur help n guidance on which kind rim&tyre to go with my car.
Thr r to kindz of "ROTA" rims tat has caught my interest, thy r....
