mike77kl
mine is not smooth coz i can feel it when it change from 1 to 2. It is an automatic with 3 speed only. i hope after i change the ATF and filter, gear change will be smooth till i wont feel it changing.
ok, thank u for telling me this. Now i know. So between the min and max is the right amount? Mind to share when and how to check the atf dip stick? If after i get it right, then must be the oil. Can u recommend me a good and suitable ATF for my old saga? It is a 91 Saga Aeroback 1.5 Auto 12V Carb. Thank u :)
may i ask is it check during warmed engine running in N or turn off engine then check? My manual book is gone when i got this car from the last owner, now i only got the Haynes Proton repair manual and it says fill between min and max no matter u change engine oil, ATF, DOT3/4, Steering Fluid, all same...Haynes recommends to fill between min and max. May i ask, is the power steering fluid can use any sort of ATF? I mean for whatever ATF i use for the tranny, the leftover i could just taruk for the steering too? I heard that we cant simply use any ATF for the tranny as we like, is it true? I got a Toyota Type T-IV ATF, can i use it for this old Saga tranny?
@Izso
I want to make a correction after i again observe the auto gear change from 1-2. There is no jerk or hesitance when changing gear, just the engine will rev up a little when up shifting 1-2. Is that normal due to 3 speed only auto gearbox?
May i know is the Diaqueen a dyno oil or man made oil? I believe is pretty damn gd oil but the price tag is a bit too much for my cheap Saga unless the oil change interval can be extend.
Bro Iszo,
looking fwd to Radiator flush as well !
How about cleaning fuel injectors the mechanical way ? I really want to learn this for a long time. Thanks in advance.
My gf's Atos Auto EFI injectors still the ori from factory. Now car clocked 120k.
Idle still smooth, never jerk when on drive. Fuel filter also still ori from factory.
I choose to pump BHP petrol since more additives to clean injectors, i guess.
Anyways, car will be sold tomorrow for 11k only, bye2 K-Car.
As for my Saga, i just change the fuel filter. Got 2 holes, in and out. I notice the holes
from the old fuel filter is a little bigger then the new one i bought. Will this add restriction
and cause power loss? Anyways, what is the benefit of a new fuel filter for carb cars?
I hope it helps save me some fuel. But from what i have read, new fuel filter will help EFI cars
save fuel while a new air filter will helps carb cars save fuel. True or not?
There's some controversy to this item. I don't really believe in the need to do this cleaning unless your car was made when leaded petrol was still the norm. Most modern cars nowadays have fuel filters so your injectors are very unlikely to get clogged if you don't open and expose them ever so often.
:sleep:
