DIY Meter Panel LED lighting
@bulet: if ur car is a wira, d trip meter light is actually a mix of d speedo, rpm and fuel meter for wira/ satria 1.3s dat dont have tacho, its 5 t10 bulbs. just changed mine recently
nice or not??...
Nicely done Skywalker.. Mind asking what LEDs are you using. Haven't really taken out my dashboard's meter to see what bulb is the meter using. Is it t5, t10 . Does it necessary needs the rare t4.2?
nice or not??...
so freaking bright man!!!
---------- Post added at 12:39 AM ---------- 6 hour anti-bump limit - Previous post was at 12:38 AM ----------
do you guys know mitsubishi lancer dashboard meter panel use what LED?
coz my ride color very dim...
hi guys, just did mine over d weekend
I got pics of mine already.
must use high farks LED mah... normal LED where got bright enough...
mitsu lancer meter should be using similar T10 bulb...
haiz.. my car meter orange color from Putra...
Put white LED also no use... Sienz.. Still orange
hi need help
newbie ya ... using mivec dashboard with 4g92 meter manual now is yellow wish colour i wanted to change to blue can tell me wat size and how much is the bulb ??
and wat do i need to do step by step pls T.T..... and do i need to take out the meter needle ??
hi need help
dismantle out the meter 1st
check using t5 or t10 bulb~
rear view meter picture got circle is the bulb need to change..
bulb size
t5 and t10
also, test before putting it back. LED have +ve and -ve (positive n negative) so if any section of your meter cluster is dark, just flip over the LED and test again.
my right signal is konk even though outside of car the signal is on. only hear clicking sound but no light flashing. wad sort of bulb isit using and can i DIY the replacement? its a wira btw,
at front headlamp there is s25...and at fender there is t10
its easy to replace it..plug and play only~
erm i m talking abt the LED in meter panel. outside of car i know how to replace but not sure if i can replace the LED for my right turn signal in the meter panel.
