Oh well, I can only say quality speaks for itself :lol: :lol: :lol:
which engine for reading boost? the intake manifold should have 2 nipples.. one connected to the BOV (do not connect your boost reading on this line). Connect the 't' fitting on the other nipple.. that way u should get the correct boost reading..Originally posted by speedster_jg@Jan 11 2005, 17:49
Yo bro,
Got some problem here.My friend have a boost gauge running off the inlet manifold vacume pipe (on the engine side of the throttle body not the blower side), the same pipe plugs into my blowoff valve to open and close the valve. Does this sound correct to you?The pointer doesn't seem to move.Need your advise! :lol:
nope.. the senders are different.. one is pressure one is temp... cannot use 1 sender for both readings... however.. the place to fit in the senders for temp and pressure can be shared in the same NPT fitting. Hope that helps.. :)Originally posted by speedster_jg@Jan 11 2005, 17:52
Yo bro,
Also , can the oil temp work from the same sender as oil press.Just wondering!
Thanks :lol:
Originally posted by jimmylkj@Mar 24 2005, 01:07
guys ... mind asking wats vacumm meter actually works for ?[snapback]835423[/snapback]
Originally posted by speedster_jg@Mar 24 2005, 12:08
lotsa usage... i copy one diagram here and post... hopefully this helps
haruan, pinjam ar diagram :P :) :lol:
[snapback]836517[/snapback]
4th February 2012, Open Track Day, SIC. Saturday, 4pm-7pm.
