Dyno-tab --- Fuel Saver--
All Other Stuff
pyn057
SUBANG
http://i6.photobucket.com/albums/y214/pyn057/DynoTab/04.gif
RM29.00 PER SACHET
WHAT IS IT?
DYNO-TAB® is a combustion chamber catalyst which helps the engine burn
more of the fuel. By doing so it improves the economy and reduces emissions.
DOSAGE RATE
One tablet treats 15 liters of fuel (treat every tank fill).
HOW QUICKLY DOES IT WORK?
DYNO-TAB® begins to work immediately as it dissolves. The tablet will dissolvecompletely within 2-4 hours, depending on temperature, type of fuel, motion of thevehicle and other conditions.
USES
In petrol and diesel fuels
Replaces lead protection
Ideal for classic and antique cars
BENEFITS
Improved fuel economy
Improved performance
Reduces carbon deposits
Low emission and smoke levels
DYNO-TAB® has been tested by leading automotive authorities in the United States and in Europe, and tests prove that it is entirely safe for both petrol and diesel engines and it will not void new or used car warranties.
E.P.A. registered with USA Federal Government – Diesel #1833-001,Petrol #1833-002
Tested by:
Ford Motor Company, USA - Fleet Petrol Economy Test
General Motors, USA - Dynamometer test
Other leading automotive authorities world wide
The Benefits In Diesel Engines:
• Reduced Fuel Consumption
• Improved Performance
• Improved Horsepower
• Reduces Smoke
• Improve Engine Life
• Reduced Carbon Deposits
• Reduced Maintenance and downtime
The Benefits In Gasoline Engines:
• Reduced Ping, Knock, Dieseling
• Replaces Lead Protection
• Extended Plug Life
• Lowered Emissions and Smoke levels
http://i6.photobucket.com/albums/y214/pyn057/DynoTab/02.gif
http://i6.photobucket.com/albums/y214/pyn057/DynoTab/cert_liabiliti_insuran.gif
http://i6.photobucket.com/albums/y214/pyn057/DynoTab/dyno_insurans.gif
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
