Edfc error EE help
sigariga
Hi friends,
Need help here.. hv juz installed Edfc on my flexs but 'EE' error showed up. EE for Front n 16 for rear. Even when unplugged front & rear connectors its still appeared the same. done reset oso same. is it due to controller fault or power wiring?
Appreciate ur inputs
my best assumption is that the wiring or connector is loose.
since sometimes my controller will display EE also,so what i did is to turn the car off and on again,then its gone.
just check your wiring first.
Egb18c,
Ok, will check the powerwires (constant & accessory) tomorrow.. do you know if there got any specific voltage/amp requirement for the controller?
case resolved.. it's controller problem. wiring checked all ok.. went to halfcut shop, swap with other controller and no more error shown.. poket kopak.. thanks anyway.
