IMPORTANT REMINDER: Read this post thoroughly before you ask. When you are calling/SMS, kindly introduce yourself (name, forum, car model).
http://www.autoworks.com.my/images/logo%20animated.gif
D1 SPEC 7-DRIVE
ELECTRONIC THROTTLE CONTROLLER
Most, if not all car manufacturers, now incorporate the Electronic Throttle or E-Throttle to their engines. The throttle was previously directly controlled by a steel cable. Modern setups are now driven by electric motors and electronics. One major reason for the car manufacturers to do this was easy incorporation of various options such as traction control, cruise control & others. A major complaint about the E-Throttle is its laggy response which makes the vehicle less responsive to each prod of the throttle pedal.
One product available now is the Electronic Throttle Controller (ETC) that essentially, works like a piggyback that changes the signals going to the car’s ECU. This ETC allows the driver to select various settings to suit their driving style & requirements such as modes for economy or speed. A throttle pedal angle of say 30 degrees, in economy mode, the throttle plate will open only 15 degrees whereas in speed mode, 62%. In speed mode, the throttle plate opens faster and wider giving the driver the sensation of an extremely sensitive engine allow fast driver quicker response from their rides.
An ETC is easy to fit comes with a set of connectors that interfaces the throttle pedal signals to the ECU. The ETC is then taught to recognize the characteristics of the car’s E-Throttle system via a few simple steps. After that, you get to enjoy the jump in instant response.
D1 Spec New Version (Slim Type) throttle controller called "7-Drive" is now available. RM500 with free installation for all models with drive-by-wire throttle. Comes with battery voltage display too. Plug & play except Campro (slice & tap). Call 019-3593909/PM to inquire.
IMPROVED features:
(1)Over speed warning - programmable speed limit to warn you upon over speeding.
(2)Avoiding from unintended acceleration - the new controller circuit is more stable.
(3)Power interruption memory embedded - the memory stays even the system is disconnected from the power source.
(4) Reverse, parking and braking deactivation - for greater safety and reliability.
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/184614_193650313990878_100000377312513_566966_7892349_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/188990_193440367345206_100000377312513_565363_4744326_n.jpg
PRODUCT RANGE: Most Japanese/Korean/Malaysian/VW/Audi (with drive-by-wire)
INSTALLATION: Provided
WARRANTY: ONE YEAR
CALL: 019-359 3909 (Drex)
Click here for Google Map
NEW!!EA Autoworks Fan Page
D1 SPEC 7-DRIVE
IMPROVED features:
WARRANTY: ONE YEAR
Half of my speedo now is in the dark.. Any one knows where to get the replacement bulb or the...
