- Joined
- Feb 21, 2006
- Messages
- 7,969
- Points
- 1,638
Elf Molygraphite 10W30 Engine Oil (3 litres)
http://img94.imageshack.us/img94/9941/elfmolygraphite10w30eng.jpg
Uploaded with ImageShack.us
Key Features
-Viscosity rating of 10W30.
-Provide excellent thermal and oxidation stability.
-Reinforced with dispersing and detergent properties.
-Superior anti-wear properties.
-High shear stability ... providing optimum lubrication at low and high temperature.
-Suitable for all gasoline/petrol engine from 600 cc.
Benefits
-Noticeable decrease in wear and tear due to cold start, especially in the morning.
-Better lubrication at all times increases engine efficiency, better fuel consumption.
-Maintain engine in silent operating condition.
-Added protection from graphite and molybdenum provide better protection and increase reliability of moving parts.
-Keeps engine in clean under all operating conditions.
RM71
Elf Molygraphite 15W50 5L
http://img7.imageshack.us/img7/9393/elfmolygraphite15w505l.jpg
-Exclusive lubrication technology incoporates solid lubricants of graphite and molydenum disulphide, ensures your engine stays clean and operates at maximum efficiency, resulting in longer engine life.
-Suitable for all gasoline/petrol engines.
-API:SL.
RM128
ELF Molygraphite 15W50 4L
http://img535.imageshack.us/img535/1467/elfmolygraphite15w504l.jpg
-API:SL.
RM105
ELF SYNTHETIC PRO 10W50
http://img231.imageshack.us/img231/7080/elfsyntheticpro10w50.jpg
-The latest in additive technology for very high performance gasoline engines .
-Exceptional cold fluidity with low pour point - instant starting and lubrication even in low temperatures.
-Cleaner engine and longer lubrication life.
-Prevents formation of deposits, varnish, sludge and corrosion.
-4 litres.
RM205
ELF MAX BOOSTER
http://img52.imageshack.us/img52/4395/218837b.jpg
2-in-1 octane booster and fuel injector cleaner!
• Restores engine's power performance.
• Maintains cleanliness of fuel system and protects against corrosion and rust formation.
• Cleans deposits on fuel injector for better and more efficient combustion.
• Reduces pollutant emission to the environment.
• One measure treats up to 150 litres of petrol or use once a month for normal usage.
• 250ml.
RM26
Elf Grapholia for Diesel Engine 5L
http://img810.imageshack.us/img810/6347/711800b.jpg
Elf Grapholia is recommended for Diesel engines operating under severe service. It meets and exceeds the following classifications :-
*API : CF-4 / SG
*ACEA : E2-96 (CCMC : D4)
*US Army : MIL-L-2104E
It also meets the requirements of most of engine manufacturers and approved by :-
*MERCEDES BENZ : Sheet 228.1
*VOLVO : VDS specification
*MAN : 271 specification
*DETROIT DIESEL ALLISON : C4 specification
*CATERPILLAR : TO2 specification
Features
-Outstanding detergency to prevent sludge formation
-Outstanding dispersancy to avoid the agglomeration of particles originated from combustion
-very high alkalinity reserve to nuetralize acid products from combustion
-superior anti-wear and anti-corrosion capability
-excellent thermal and oxidation stability
-excellent protection against bore polishing
API: CF-4 Classification.
CF-4 for High Performance Diesel Engine
This category was adopted in 1990 and describes lubricants for use in high speed, four-stroke diesel engines. API CF-4 lubricants provide an improved control of oil consumption, ring groove and piston deposits.
RM110
DREGO IMPORTS
0123505832
PETALING UTAMA
Key Features
Benefits
RM71
-API:SL.
RM128
-API:SL.
RM105
-4 litres.
RM205
ELF MAX BOOSTER
• 250ml.
RM26
*API : CF-4 / SG
Features
RM110
DREGO IMPORTS
0123505832
PETALING UTAMA
