pimpin323 said:iyo i'm looking at around 5k la guys. basicly its gonna be a new b6t engine. basicly this is the plan.
-new pistons/rings
-overbore the block abit(engineering charges)
-new bearing set(crank,conrods,etc)
-new gaskets seals(hopefull can fix that leaky dizzy)
-new/old crank shaft(from a miata engine)
-using old conrods
-engine balancing
-same gearbox
-same c/head
-labour for taking the engine down and workman ship yada yada
-180 cold side turbo upgrade
-front mount i/c
the only problem i'm worried about is sufficient fueling and if the stock ecu can give enuff juice. a new management system is out of the question. maybe a piggyback just to fine tune. not looking for crazy hp just a reliable ride. 200hp target hopefully more torque.
What do u mean by 180 cold side upgrade? means hybrid with VJ20 cold side?
And u doing a FMIC there?
I am running hybrid VJ20...
If you planning on running at 1 bar, most probably wont get 200hp...(I dynoed before).
But its near....maybe at 1.2 bar... :)
I havent tried it cause money went to another project :)
