I heard many without any solutions. :\
the problem does notnhappen on my friend persona elegance.
mileage is 115k km.
Yeah! It also doesn't happen to my friend's Persona too
---------- Post added at 09:08 PM ---------- 6 hour anti-bump limit - Previous post was at 08:21 PM ----------
I talked to the same service guy this evening, he said that although the PDT did not detect any fault with the car but he strongly believes that a particular relay maybe defective. So I straight away told him to order the relay. Will replace the item next week and see how it goes
Did you sent your car to any service center to check the problem?
Yes. Wanted to reflash ecu but the Section 13 sc is so damn slow. From 10am to like 3-4pm.
I'm like, Fcuk this shyt Im out.
Problem is idk what is wrong. DIY OBDII diagnostic also ok. DIY maintenance so I know I have done everything right.
Jom, we take your engine apart with bro. Izso.....His tools, my tools plus yours should have enough....hahhahhahahah![]()
His one also not enough wor. Need precision tools.![]()
Cannot open we improvise mah!...hammer wallop......hahhahahhaha![]()
Last Thursday, I poured Bardahl Injector Cleaner in the fuel tank. Since then the car does not jerk anymore. The rhythm of the engine sounds smooth, back to normal as it used to be. Could it be that the Injector cleaner has helped to solve the problem? I don't know but I will observe the situation for a few days more.
cross breed of godzilla and jz engine
