Engine keep idling.
wira3319
Hi guys,
Could you help me on above problem? i have change to 4G63 N/A, but the engine cannot running smothly and i suspected from control sensor map. i have change it already but didnt get any effect. i didnt know what to do anymore. the engine cannot running smoothly when i turn on the air cond and regarding from that, the engine also can shut down without any signal...
Regards
wira3319
dun understand the topic 'engine keep idling'?? wat is suspected control sensor map? which sensor did u changed? what engine r u using? what ECU r u using?
is ur stepper motor in good running condition?? sound like engine only can be halt when air con is turn on.
check your maf sensor, throttle body, ISC, stepper motor
"Engine Idling" in Car Modification forum? .. i suspected he wanted a Turbo Timer at first.. wrong question ..
