Engine Treatment/Oil Additive
What about mixing tufoil with Mobil 1 Fully synthetic oil? Is it okie? I'm afraid of it not being able to bond together with the oil.
other than Ace , Eneos , any other places that sells it , i'm along old klang road , wanna try it since the tetpet gone worst ... even servicing every 3.5-4k with castrol semi syn ...
p/s : this is a bit nooby , so it engine treatment or additive ? confused , scared later buy bought the wrong thing haha
Hi! Pillage2001.
I would have thought you are a long time user of Tufoil as I often bumped into your interesting posts some 7-8 years ago.
Anyway, Tufoil has a synthetic base incorporating ester. Tufoil mixes well with both mineral and synthetics.
And to you liz@rd, along Old Klang Road you can get from Mission Car Care 0122342691 and FD Jaya Motor 03 77832203. If it is convenient to you, there is an ACE Hardware at Central, Level 1.
Cheers to both of you! There must be many of you out there who have been using Tufoil for a cool 10 years already. Salute and Bravo!
Hi! Pillage2001.
Hie Focalpoint, I'm a long time user of Tufoil but ever since I've got my new Accord and changed to Fully Synthetic oil, I stopped using it for awhile due to the cost but am contemplating the use of it now. It was awesome for me before and pretty sure it'll be awesome for me if it's okie to be used with fully synthetic oils. :) It's okie to be used even if I change my oil every 10k km?
For those who are in PG, Jusco in QB and Tesco carry tufoil at 59.90. :)
Sure, I knew you were one of those who posted about Tufoil, pillage2001. Thanks for your loyalty and we are certainly glad to hear that the product has been awesome.
Regarding oil change whether at 5K or 10K, we would like to leave this to your judgement. It is always important to check the oil dipstick. Make sure that the level is always between the min and max levels when engine is warmed up. Next, visually inspect if the oil is still clean. Simple steps like this do help. Rgds.
no need additive @ oil treatment
just change ur engine oil regularly
for me im changing for every 3000km
so it will be once a month :smokin:
ha...tats y ur corolla so tip-top condition...:rofl:
P/S:i bet u knw who i am...^^
i tried X1R into my ride...still cant feel any difference yet...
also pumped in petrol treatment into my fuel tank....still same i guess...
Yes, engine additives are scams.....hehe......Using castrol managtec is good enough, trust me! Dont need buy expensive oils either...
Scams! Certainly, not Tufoil.
Yeah! The US government will not test a scam. Period.
Jz get 2 bottles of Tufoil. Waiting for my nx eng oil after 3 to 4 more full tank of petrol and waiting to feel the effect..
jz wondering wat eng oil i can use to mix wif tufoil.. hehe
Thanks for the purchase of 2 bottles of Tufoil, xing55.
You may partner Tufoil with the motor oil you are currently using so that you are qualified to make a A and B test. Over the years, there have been many matchings by readers of these thread and other users. Nobody is right or wrong, we suppose. Only the one behind the wheel can say something.
as i know, those additive will not mix together with the enigine oil.
those additive will stick on all the engine parts like bearing......to make them less friction and protect on it.
Izzit cheaper if i get it from tesco? gonna get it for this saturday changing engine oil routine. thanks for all the explanation now i got the right engine treatment oil for my myvi.
i've used Bardahl 1 & 2 oil treatment for my 13 year old Wira workhorse and found it to be a good match if i were to use mineral & semi-syn engine oil (apart for Magnetac which i believe do not require any more additive)...
for fully syn, Bardahl has no effect i were to use Mobil 1 & Syntium 1000 but still give good results if i were to use Helix Ultra..
but now, i'm now trying Tufoil and wow, it is much better than Bardahl where my oil consumption problem has completely stopped!!...
reason i switched to Tufoil was investigate whether it could lower my FC but the results were very marginal, ie. less than 1 - 2% (probably cos i'm already on additives previously)....
but my morning start vibration (my carbie choke already 'kong') and oil consumption problem has completely gone which i did not expect for such results....
i'm currenly using fully syn Penzzoil Platinum and as you guys know, this oil will evaporate very fast for old workhorses like mine but with the Tufoil, this problem has been resolved...
morale of the story, experiment with a few products and you will know which is best for your car
Hello where, can I get Tufoil? I've searched through Enoes and AceHardware, still don't see it. I'm pretty interested.
u go to ace hardware in ikano power centre.
they have it there.
