Fc Suddenly Boost Up ! What could be ?
Norns
Initially my car had problem , car keep choke in lower rpm while increasing ...
Was using denso iridium and 9.8mm performance plug cable.
So i went to 1st foreman, he say performance cable can only match with 'normal' spark plug. So he change it to normal rm30 spark plug.
Problem still persist.
Next, i went to an indian foreman. he change to normal plug cable ... and problem persist. so he confirm n change to another 2nd hand distributor too.
Now problem free alreadi.
But i can see my fc really increase a lots !
Previously rm50 can up to 300km. Now rm50 just 200km onli ... and its been 3 weeks ...
What is the main culpurit for my fc ???
So i went to 1st foreman, g.he say performance cable can only match with 'normal' spark plug So he change it to normal rm30 spark plug.
what the first formen said is not true.
second off all try n check ur distributor.the formen might temper with the
distributor setting.
the indian foreman just change the distributor onli. no setting done.
but now i feel like harder a bit to start car . I mean hav to turn the key slightly longer time ...
distributor replaced and most probably the AFR din set lo....:biggrin:
and do u put bc ur iridium plug n performance cable?
my2cent
ignition timing set to solve the prob of ur car, but didn't match the proper AFR. just try to check ur Voltage coz this prob mayb will be cause from it.
i think solved my problem. go to one workshop in ss2.
he offer me rm15 for tuning (use torchlight n knock the distributor)
and he suggest me to add rm50 to put in the electronic device to do scanning (just 1 minute)
now it seem my fc is normal for this 3 days ... will keep monitor ^^
hahaha...my prediction is right to the spot...can go buy Toto liao...ahahaha...:biggrin::biggrin::biggrin:
