Flashing strobe lights
BUMP!
blink! blink! blink! left side
then
blink! blink! blink! right side
Put into Hella spot lights to get the brightest flash.
Many thanks to Honda City club owners for buying my sets (",)
i have question! what if i put inside a h3 size fog light? which mean i no longer have the fog light function because it's been replaced by the strobe light? So whenever i switch on the fog light, no light but only blinking strobe light?
That's what I did. I replaced the small h3 bulb with the flash bulb. If you do what I did, whenever you switched on the fog light... you will be flashing away :)
i didn't mean to ruin your business here... but i think i should tell my experience using this item... this strobe is quite slow flashing and the blink rate is not consistent,meaning sometime it bling 3 time and sometime it blink 2 time... and about the brightness... it actually hardly noticeable in daylight... definetly not even close to the F1 marshall car... nobody would notice in the day light unless they look carefully.
and lastly if you use a hid bulb, your hid beam will actually make your blink2 unnoticeable. just think carefully b4 u buy guys.
all talk is no use in here, you should see my actual installed product before making a remark here and call me to meet up and show what actually happen and solve the problem. I am using a HID with new headlights. I invested in Hella spotlights and put my strobe lights into it to get the best effect and flashes a far distance. I do not have thousands of dollars to buy those F1 marshall cars strobe lights so I will have to make do with this product.
did you install into a place where it cannot be fully utilized? did you cut the original wires? how many amp is your battery? condition of battery? wiring to the switch is soldered properly? gosh, so many other factors to be asked.
what i mean cannot fully utilize is, for example if i use a HID bulb in a headlamp where the reflector is not so good after years of service, then it will not shine the floor properly. then i cannot simply advertise publicly saying this product is useless, i can get sued for that.
my demo car is available for viewing.
do u provide installation.... u said it can fit on almost any place.. do u mean that it come with universal socket>?
Sorry, no installation provided. COD only. The socket that surrounds the bulb is rubberized. You can cut the rubber to the size you want and fit into the place you want.
For my case, I used hot glue to just sealed the bulb in place and to prevent water from touching the bulb.
It comes with one set of blue covers, one set of red covers. wirings and the controller to set the pace of flashing and the pattern of flashing.
sms to me if ur demo car around kl area exp: sogo/maju junction..
i wanna to see. tq.
013-952 7343
i wanna to see. tq.
013-952 7343
okie dokey, will sure do. better be quick, I only have 2 last sets. might not have anymore stocks in future. will update here. thanx.
fatsub
called u and sms u last sat
but no reply
0126526655 is my number
Hi... sorry about that. i check both my phone's but did not see your number.
Anyway, you can PM me Monday-Friday.
Got one last set only as of today.
chew118 said:
fatsub
but no reply
if this is the last set then how about the warranty claim
As normal procedure for last set, I will refund the money if item found to be faulty.
Last item has been booked by honda city club. I would be selling to one of the members tonight. Thanks to this club who has bought many many units from me.
Cheers! I would update here if i manage to get new stocks.
Sold off 2 units last night. One unit for sale now from my car. Strobe lights plus 2 Hella Comet spot lights plus Hella white covers. Refer to picture below. The Hella white cover not shown in the picture.
RM190 negotiable
MAX 2000 strobe lights - RM370 COD
New stock just arrived for MAX 2000 strobe lights.
RM370 cod.
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
