Focal: 165V2 vs JL Audio: XR650-CSi
skr
i need some help here...which speaker do u think is a better buy....i was quoted rm600 for both sets...below are the specs of each
Focal: 165V2
Product Features
2-way 16.5cm (6.5") component speakers
Woofer: 165mm.
Voice Coil: 25mm.
Motor: 84mm.
Tweeter: Tioxyd 5 TN 47.
Filter: 2-way 12dB/octave (adjustable tweeter and midrange level).
Max. power: 150W.
Nom. power: 75W.
Sensitivity: (2,83 V/1m): 93dB.
Frequency response: 60Hz-20KHz.
Grilles supplied.
Product Description
Midrange/Woofer:
Zamak Chassis
Polyglass Cone, Butyl Surround
Tweeter:
Push Pull 20mm Neodyme magnet
20mm diameter voice coil with aluminium former
JL Audio: XR650-CSi
Product Features
Nom. power handling : 70W RMS
System Efficiency: 89.5 dB @ 1W/1m
Frequency response: 58 Hz - 25 KHz ± 3 dB
Mounting depth: 71.4mm
Woofers/Mid-range speakers:
Mineral-filled polypropylene cone body
1.0 in. / 25 mm voice coil
Low-profile/symmetrical-roll spider
Butyl rubber surround.
Tweeters
1.0 in. / 25 mm aluminum dome tweeter with rubber surround
Neodymium magnet
Ferrofluid cooled and damped
Variable mounting system with swivel / rotation capability.
Grilles supplied.
Crossover Networks:
2-way network with 1st order low-pass and 2nd order high-pass circuit.
Premium polypropylene film capacitors and air-core inductors.
5-position adjustable tweeter output level.
3-position midrange presence control.
Polyswitch tweeter protection.
so yeah....just leave your opinions as to which is the better deal...thx
just based on specs id choose the focal as it has higher power handling and has higher sensitivity. focal has a good track record on speakers, jl has made its name making subs. so if we were comparing subs id take JL over focal. however best is to test and see which u like. ive never listened to the JL comps yet, so cant say lah..
Hi, this just base my knowledge only.... Comp with high sensitivity...very good high mid & lack at low mid... Focal V2 can get RM600 ...wooow so cheap... original 1 or immitation 1... Focal can not tahan with Hot & Cold wheather loorrr... I'm using Utopia before RM1300 (mid) pc.. after 1 year ..cone bengkok sana & sini..Ori 1 with serial no. some more from audioactive ... I'm asking the seller why & what happen.. they said not due to water but temp inside the car...sometime hot & suddenly cold..or sometime cold & suddenly hot...
so cheap.... yeah, as oldskolboyz mention, beware of imitation speakers... if it sounds good, then imitation also nevermind la... since its not that expensive. Go listen to more speakers before deciding.
RM 800++, its not also just the price... sometime imitation also same price
My advice, buy it and ship it yourself from ebay US or where ever the speaker is produced, with the shipping plus the cost of the speakers it comes around the same price as we purchase here in the accessories. Then DIY the speakers your self. Trsut me even then sound not that good but u will be satisfied. hehehe
