gaining extra HP and performance >>>
emo
subang jaya
guys, what can i do to a 4G92p to increase its performance.? (stage 1)
a bit new here and to modding industry..eheh,..
can anyone giv a short explanation (uses, pros & cons) and some (reputable brands) to these devices..
1)air filter
2)heatshields
3)cold air intake
4)MICROCOMPRESSOR
5)voltstabilizer+earth grounding
6)extractor+exhaust system
what exhaust setup/system is best use on satria 1.6manual
7)performance sparkplug+cables
8)which sport/lowering spring is the best
(for 195 50 RIMS 15)
9)the use of strut bar/stabilizer bar/anti sway bar?
(im not sure which one using in 1.6)
And what other things i can do to increase its performance apart from the thins stated above?
your time and guides is really much appreciated.
thank u!
1. air filter: high-flow drop-in, or open pod with CAI.
2. heatshield: included in the CAI setup
3. CAI: included in the filter mod
4. MC: forget about ANY air leaking device.
5. VS + GK: A good VS paired with a set of customized GK
6. exhaust: 4-2-1 + mandrel-bent piping (1.8" dia.) + mid resonator + twin pipe S-flow muffler
7. BOSCH Super 4 with stock cable
8. Eibach
9. upsize your rear antiroll bar to 16mm will do. UTR is recommended.
You have missed something in the list. A lightened crank pulley. http://drexchan.fotopic.net/c1137619.html will help you in understanding what it is and what it does.
emo,
no need to waste those money for that, either rojak with 4g93 become DOCH or Mivec...
the more u modified the more u will waste money on it...
the best way is straight away change engine to 4g93T...
good luck with ur modding...
