Gear SERIOUS problem .. urgent pls
i think to shift down to gear 1..it is advisable to do when in full stop.. gear 2 is strong enough ...why need gear 1 while moving? the rpm will be quite high while moving..
I think his problem is hard to shift gear up and down (1 > 2 or 2 > 1), especially when high RPM or car moving fast..
izit a real problem??i tot any car would do the same..why wanna downshiftting to 1st gear while u moving?1st gear only use to initiate the car to move only..i read dat sumwhere..
Normally clutch finished if difficult/hard for u to shift gear from 1>2>3 and after u shift the gear ur car felt like lossing power coz when ur clutch pad "kong" already and cannot grab the flywheel and cause clutch slip or more seriously cannot grab the flywheel at all and last ur clutch will burned.
That's my experience...
