Done that before. But doesn't help much on the sound. Change the VVT pulley to an adjustable ones. You will eliminate all the sound + a little better torque....
care to explain how and more info pls.. and how much will it't cost?
thks..
yeah. valve vs shim clearance.
Reshim job might be take time... it not so easy like juz change to the other set.
machanic need to measure the tolerance.....
The 'Teksi' sound usually come from the VVT pulley,take it out and clean it,should fix the problem
