minikar said:
Plug also, check the plug color
On 2nd thought, since now idling still very smooth, plug shld be still ok, right?. Besides, i also occationally clean them using dremal wire mesh. Last time clean it 2 weeks ago. Its NGK G power, tiny platinum tip, single arch.
minikar said:
You spent several K in fixing the rpm prob, why don't you do a compression test (wet & dry) as well to prove me wrong that your car don't need a top overhaul.
Frankly, repairings + upgrades + servicings, its does costs several k, but spread over several years of my ownership lar. If all happen in 1 year, me also pk lar like that. Ha ha ha ha.
I recalled major ones: aircond compressor & service >rm500, electronic distributor cost about rm500, 4 pcs of tyre > rm400, tacho meter about rm200, timing belt > rm200, new ori 80v alternator about rm400, recond 90V alternator rm140, engine mountings few hundreds, water pump rm160, ATF machine flush twice about rm400, rear absorbers about rm200, engine top & mid block gaskets + carbon clean > rm500, power windor bracket + door lock set >rm300, anti-theft metal plate + security ignition lockset about rm300, 90W head light wiring rm120, mini compressor & GK & magnet >rm300 etc damn long list to go on.... Me also lost count already :embaressed_smile: ..
minikar said:
A small leak in your combustion valves might hv caused your car too big load for low rpm, when engaging air-con and heavy alternator
But then my case aircond dont cause problem to RPM wor. Alternator reading is also ok, charging >13V anytime. whether its 80v or 90v altornator.
Just the head light distort RPM only (after install 90v alternator), although now (put back ori 80v alternator) is really minimise distortion already, just that still not 100% disturbance free if switch on head light. He he he, previously (b4 change to 90v alternator) is 100% disturbance free, so now i just wish to fix it back to old time's condition, guess i asking too high liao :embaressed_smile: ?
So about the lost in compression & too high engine load, doesn't sound like its relating to it? since idling RPM steady, engine smooth & aircond & alternator still run effectively?
If really lost compression alot, shld result in white smoke already right? & also serious lost in power right? But mine no smoke at all & not lost alot of power wor. But of course its not as powerful when its was new fr factory lar.
I also wish to top overhaul too, fancy for clean, rejuvenite, lifeful, efficient engine :regular_smile: but now PK already lar, somemore top overhaul is not urgent issue lar....
Soli for being long winded....:embaressed_smile: & but really thanks to all sifus
