[HELP] Iriz Rear End Hopping
stock tyre is silverstone....definately it was on the stiff sidewall....
thats why i'm recommending lower tyre pressure than stock....
try open irix rear door. try sit/ press (left and right side) and see hows the rear suspension move up/down. Fast or slow.
Might be one side of the shocks/absorber give way.
Well, other likely chance is stock suspension jammed?
Maybe I will go to ftuned to have the suspension system check and also at the same time check for any tyre failure.
Personally, I found that the stock tyre is incompetent
Will get back to everyone soon.
Thanks.
It's a relatively new car so should not yet have suspension problems, let alone jammed suspension. If it does though, sorry to say that means the car quality is crap! I still think most likely is due to the shitty stock tires.
To us is likely the tyres or suspension. Since tyre reduce air pressure still like that , that is why maybe need check suspension....lol
Yeap I have tried your recommended tyre pressure, still it skips during cornering:confused:
Then next tyre change u can look into more comfort tyre category...
or to my earlier suggestion, change into a softer rear springs...
i believe that u were looking for better comfort?
Iriz original tyre size should be 175/65R14, tyre should not be that hard being 65 series aspect ratio?
Personal check on suspension system: seems normal being not too slow and not too fast.
Tyre pressure: I have adopted the recommended range by pomen_GTR
Tyre: 195/55/15 silverstone, which I believe is a terrible tyre.
I'm actually prefer sport handling with little stiff ride.
If using 195/55R15 there are many tyre choices......:driver:
