after my car wira 1.5 (A) fatch 5 people to Genting my car started runing wired.privious my car runing 100km/h in 3k rpm but now it runing in 3.5k rpm someone help me tell me why ,it look like the gear box not function properly like draging
5ppl in Wira auto .. is possible, wont worry, just send for a mild servicing. Recommendation for usual Genting guys is .. often service their car for normal conditions.
hmm like tat, same problem with mine... but mine only like tat if my engine is cold, my rpm is 5 but da spd only 25kmh~ but if engine warm... den da gear 'makan' dy, for me, i jus changed my gear oil ~ so tat mean my torque converter not working well
so, myb ur gearoil or torque converter got nid to check... torque converter = clutch for auto
erm still havent fix... cos torque converter hard to find a new 1... if 2nd hand easy, so i think it is not necesary to change, btw only da engine cold da gearbox act like tis
yup
torque converter...if manual is the problem at the clutch...
ur torque converter should be facing problem for a long time liao just that it wasnt significant until u use it very hard when going uphill
I'd like to know if you guys had a choice between both these tires,which would you choose? These two tires only! I've read about the Goodyear GT3 being an underrated tire but is it as good as a...
