The HKS AFR (Air Fuel Ratio Regulator) is a simple fuel adjusting device that adjusts the air / fuel ratio by changing the airflow voltage output to the factory computer. The AFR was designed for vehicles that are lightly tuned (air cleaner, exhaust system, header, etc), and that only need slight fuel-adjustment. The 10 setting adjustment indicator allows the user to richen or lean the stock setting by approximately 1.0 A/R point in either direction (richer or leaner). Each notch on the adjustment indicator will adjust the A/R by approximately 0.20 of an A/R point. Both the lean side and the rich side have 5 adjustments.
Rm200 its really cheap!!
Call 016-6117868. Do not PM!!! Helping a friend to sell. Thanx.
http://img.photobucket.com/albums/v209/rodzthomas/hksafr.jpg
