:P
Jeineilsen this my carOriginally posted by 3R1C@Sep 20 2004, 22:35
http://img.photobucket.com/albums/v155/taihpin/zth/S_04/S_0401.jpg
http://img.photobucket.com/albums/v155/taihpin/zth/S_04/S_0402.jpg
http://img.photobucket.com/albums/v155/taihpin/zth/S_04/S_0403.jpg
http://img.photobucket.com/albums/v155/taihpin/zth/S_04/S_0404.jpg
http://img.photobucket.com/albums/v155/taihpin/zth/S_04/S_0405.jpg
bro jineil2en, if i'm not mistaken so4 said his car is the black one. not the white one.Originally posted by JINEIL2EN@Sep 30 2004, 17:18
SO_4, give me ur EK's mod spec, i wanna post in "the perfect way to mad mod an EK 4 door" :D
huh?Eric?did you?Originally posted by PetrolHeaD@Sep 30 2004, 17:44
ERIC!!! u turbo'd your coupe??!!
Exterior-
Body:
STOCK looking
-Except for the wanna be Type R 'H' emblems lol
-OEM Headlights - black with JDM style 'city lights'
-9000/10000K color temp Santeca Thunder Beam HID kit
-Type R/Si front and rear lip
Wheels/Suspension/Brakes:
-17" Ray's Engineering Volk TE-37
-Yokohama 205/40/17 - will change to 215's eventually
-Tokico 5-way adjustable illuminas
-Ground Control/Eibach coilovers
-Type R front upper strut tower bar
-Front & Rear FULLY adjustable 3 degree Sprint camber kit
-Brembo front & rear cross-drilled and slotted rotors
-AEM/NISSIN brake pads
Interior/stereo:
-Alpine in-dash CD player/TV IVA-800
-Farenheit in-dash TV-tuner, DVD/CD/MP3 player
-2 Rockford Fosgate HX2 12" DVC 1000 watt max each
-2000 watt performance technique amp
-Sony 3-way speakers in front
-Sony 2-way 6x9 rear speakers
Motor/Gauges/Turbo/etc.
-Autometer triple gauge pod
-Autometer carbon fiber series BOOST gauge
-Autometer carbon fiber series mechanical OIL Pressure gauge
-Autometer carbon fiber series WATER Temp. gauge
-Autometer shift light
-APEXi white face EL backlit EGT - exhaust temp. gauge
-APEXi Turbo Timer
-APEXi AVC-R Electronic Boost controller
-APEXi World Sport catback exhaust system
-AEM Tru-time adjustable cam pulleys
-Unorthodox pulleys
-Lightened Aluminum Flywheel
-B&M short throw shifter
-Fluidyne high capacity radiator
-Golden Eagle Vacuum distribution manifold
-Electric exhaust/downpipe cut-out (e-cutout)
-G'Reddy oil filter distribution adapter
-STR cam oil seal
-3bar map sensor
-Golden Eagle Goldzilla Sleeved Block
-CP Pistons 81.5mm 9:1 compression
-Eagle Rods
-Drag Gen3 turbo kit -modified
-Spearco front mount intercooler
-Precision SC61 Turbo
-HKS SQV blow-off valve
-TIAL 35mm wastegate
-255 lph Walbro fuel pump
-ARP head studs
-Hondata S100 with boost on P28 ecu (1995 sohc vtec)
-OBD1 to OBD2 conversion harness
-Siemen-Deka 880cc injectors, with stock Honda resistor box
