How to choose engine oil?
elviraz89,
Stick with Motul or Royal Purple will never be go wrong.
It will last longer then u could expected, save your time n money in long run.
Let say, if you try to budget your expenses on lubricant.
Just stick with Petron or Shell (only source in Petrol station), it will do OK...
Been a motul fan for a long time, Htec 5w30 and also used 300V 5W40 before,
but since my mechanic recommended shenzo JAPAN oil
Buy Shenzo Racing Oil Japan Premium Engine Oil - Malaysia Online Store
never used motul after that :)
personally feels that it last way way longer and smoother compared to motul,
used shell helix too, smooth but engine feels heavy.
Shenzo 5W30 all the way :)
cool thing about it, the engine oil is blue :D
possibly a way to tell if its genuine or recycled
Wah! all 100% synthetic? No semi or mineral?
---------- Post added at 08:24 AM ---------- 6 hour anti-bump limit - Previous post was at 08:24 AM ----------
found penzoil 7L 15w/40 for rm85 but don't have time 2 check the spec
7L usually is diesel oil packing.....:driver:
Personally I use Motul 300V for Turbocharged car, Castrol Magnatec Semi for Mivec Car. Always overshoot the mileage by few hundread km's before change out.
Quite worried buying cheap oil as Malaysia are known for recycle oil@fake recycle oil.
Owh one more thing, when i'm testing different2 oil I can feel difference in acceleration and tappet/lifter sound. (this could be the indicator on how you choose your oil type or rating 10/40 15/50 etc)
If somebody have place to send metal element/compound analysis before and after would be good too.Would be a good indicator on how the oil/additive inside the oil perform over long cycle
This one is mineral oil, right?
stated rm99 before promo @ the bottom left of the price card, so usually that price is semi price & the api sm is usually semi oso
Well if not mistaken Castrol GTX is mineral oil. I had been using it in my old wira..
Im not sure about other countries but in malaysia i think it goes like this:
Castrol Edge - Fully Syn
Castrol Magnetec - Semi Syn
Castrol GTX - Mineral
However, it is not stated in castrol GTX bottle whether it is mineral or semi. I could be wrong too.
That is the thing. Have been following it those days, and GTX was mineral....
---------- Post added at 11:30 AM ---------- 6 hour anti-bump limit - Previous post was at 11:22 AM ----------
Nope, you don't read SM rated as semi. SM is the rating they get when oil is sent for testing, so mineral also can have SM. Mobil Super 1000 is mineral and already SM rated
read edi @ back botle stated premium quality base oil so that means mineral edi, so which u guys prefer,semi api sl @ mineral api sm?
No preference because both can be used. API SM and API SL are just the standards being referred / tested. No big difference between these 2..even API SN
that means regardless the spec u'll go for cheapest 1 rite?
---------- Post added at 04:57 PM ---------- 6 hour anti-bump limit - Previous post was at 04:56 PM ----------
that means if go cheaper oso should be no prob rite?
Was told most test nowadays is towards environmental friendly stuffs.....:driver:
---------- Post added at 09:37 PM ---------- 6 hour anti-bump limit - Previous post was at 09:36 PM ----------
Can lah! I have been going round buying the cheapest too.....:biggrin:
Oh definitely. If my car can run on SM, why do I need to pay more for SN? Unless I try SN for once and I feel the difference. But usually there isn't any noticeable difference
