how to install moderno side mirror
you have to test the connection from the 12v batt. connect each wire to the same colour code to the mirror control relay and try it one by one. then after you satisfied, label all the wire. try it... ;)
bro my original dont have wan im using a 660 kancil so there is no wire at all
easy la... just find +ve wire or you can hook up at your keyon switch for powering up the relay module of your precious side mirror... kekeke :)
bro since urs dun have the wire, u might 1 2 do all the wiring on urself. ok well u might 1 2 consider looking for the + ve and the -ve which the motor for ur auto fold motor. this is where u might look for ur power source, either from ur alarm or ur key ignation. so it depands on wat u require. if u manage to get those two wire for the power to ur auto fold and there is where ur power relay comes in. for the rest of the 3 wire, there is one on both of each side mirror u need to connect together and the rest is to the switch. well for me if u r not those in wiring, i would suggest tat u send it to the wireman for it, dun bcoz 1 2 save tat little cost u damage ur side mirror. so ur choice. take care man.
