I am a bit fussy to spend on that pricey 'boost controller' and some says that the alternative is tulang ikan..How to install it? And is there any bad consequences if we installed tulang ikan? Making enjin rosak so soon?
Aura said:I am a bit fussy to spend on that pricey 'boost controller' and some says that the alternative is tulang ikan..How to install it? And is there any bad consequences if we installed tulang ikan? Making enjin rosak so soon?
Aura said:So if no problem with your engine, how to install it?
cateyes said:before ur T hose actuator put ur flowerhon fishbone.
must remember it will not remove the boost cut as it still remain boost cut.
With Fishbone:
Watercooled turbo boost cut tested only go 1.0bar
Oil cooled turbo cut tested only at 1.3bar
See at GTTikuning pics there goes the fishbone.
cateyes said:With Fishbone:
cb70 said:Hi cateyes,
Whats the difference between watercooled turbo boost & oil cooled turbo boost? I assume in any turbo-charged car only 1 of them can appear at the same time right?
For gtti, which 1 applies? :willy:
gtti_kuning said:depends...
some GTti run on water n some run on oil...
like mine is running on oil.....
Aura said:I didn't know that before..I'm just my car every weekend and change oil every month..That's all I know..
waaa....Aura said:Not yet lah..Must refer to pomen first..
gtti_kuning said:waaa....
must refer pomen first aa?
last time i install never refer pomen also..
just installed my self only....:D
...i install tulang ikan bilis lor....:tongue:heckler said:what kind of tulang ikan u install??? ikan semilang or ikan siakap??...
Philip said:guys..i'm installing a boost controller myself, I wonder where to get extra vacuum hose?
Philip said:its an electronic boost controller..wiring done..just need to get vacuum hoses to connect the IN/OUT..coz the stock OEM hose connected from the turbo to actuator is TOO short..
any idea where can I get reliablie hoses?
How to remove boost cut viva?ya lor...
if want 2 remove boost cut u need a T hose,one way valve n tulang ikan....
just plug in ur T hose at the map censor ...
then install that one way valve n lastly d fishbone.....
i'll up d pic later.....
