How to make ADJUSTABLE HI/LOW abs softer????
kiran84
dunno
Hi all u guys...........
I am using a set of TEIN adjastables HI/LOW only....do not have soft/hard........
i want to make it softer abit as it is very very hard now...meant for track i guess???
can i change the springs or do some thing with it to make it abit softer also enough???
PLS help me on this......sayang to sell also,bought so mahal ..........
thanks guys......hope someone have some idea on wat should i do....???
hey yong...long time no seee.............
remember me rite....
change spring rating arrrr? how to do that???
where can i do that??? how much agak agak ???
thanks man...for all the help......................
step one: remove them
step two: throw them away
step three : buy koni c/o kit
step 4 : install
if not happy
step 5 : remove and adjust
step 6 : install again.
if still not happy, repeat 5,6
Yes the absorber can be sent to have its damping re-set.
The HWL manufacturer in Sungai Buloh does it.
Of course besides that, get new springs with a softer spring rate.
Coilovers can never really be fully comfortable. Take it out and have a look at even the softest set of springs for the coilover and then you'd get what i mean.. :)
Nop...
teiN Hi/Lo caNNot be softeN ........ oNce its hard, foreVer hard.... if its softeN thats meaN ur adjustabLe 'koNg' oRedi..... kua kua kua....... it wat ajdustabLe suspeNsioN 4 wat, Lowered & Less bumpiNg..... thats wHy its hard..... so coNNeriNg 'sYok' oooooo, feeL Like ur stick to the grouNd...... hehehehee..... try koNi Laaaa..... few freNdz try oredi..... most of them satisfy with the performaNce....... Now i thiNk its abt RM1400 oNLy......
rock OOOO!!!!!!:rock:
You can take your spring out and get a suspension tuning shop to rate it ... Then get some coil-over spring with about 20-30% less rate. Normally the bump rate on the so-called racing shocks wouldn't increase anything more than 20% of the overall stiffness. The rebound shouldn't be a problem with softer spring.
Getting new springs is probably cheaper then getting a whole new sets of suspension.
Coilovers are not designed to be comfortable, like what the others said.
Want comfort? Use stock.
yup,
if u reaLLy waNna comfort use origiNaL stock........
coNfirm comfort........ u sHouLd reaLize the fuNctioN of these
adjustabLe maN...... its Not made for fast road, it was made for track use,
draG battLe,coNNeriNg & wat so ever mean for race use purpose....
so better get use to it if u reaLLy waNna be iN motorsport worLD!!!!
RoCk OOOOO!!!!!!
