agreed. . but with 700 rpm different consider how much is power output achieve?
and referring to power/torque graph for k3ve2, 6.8krpm-7.5k rpm is already goin down means actually lost power not gain power. . .
i just bought a car which is wira that use 4g13 engine. the car has make a little modification such as Air intake, lightning crank pulley, adjustable cam pulley and high cam. This modification has made by...
Any sifu, help needed!! It's a very annoying problem. I've owned a proton wira 1.3 carb. De problem is de locking. It comes with an alarm system. When I unlock de door by either using key or remote control, de lock...
Guys,
My clamp keeps getting loose. Look at this nut, is it meant to be tight or its suppose to have some freeplay? Can i lock it tight permanently with some threadlocker??
