Kembara FC
Sure u can just drop your a post here. When ever i got time n see your post i'll try my best to answer u.
As for the person u said she did 140kph @ 3k rpm is near to impossible. I once drove customer p. perdana, t. harrier i did 120 kph @ 3k rpm.
Oh yea b4 this u mentioned a fren of yours said your gearbox slip or somthing rite ? I just remembered theres a part call "torque converter" it actually act like a clutch to your gear box. That part tend to create less torque as car age goes. Its like 100 % power from engine, u should get 100 output. Now that part slightly slip abit, u only get 80 % of power. So u want that 100% power output, then u will up your engine power to 120% only to achieve 100% power output. This case of course xtra power = extra fuel burn = poor FC ...... Hope u understand
okay, small typo error there.. haha:)
she did a 140 at 3.5k rpm, which shocked me itself. the engineer also told me that I would be going 140 also with that RPM. which lead me to believe that something is wrong with my car.
I understand that adjusting the power will burn more fuel. but currently I'm already burning quite a huge amount.
btw, it's possible to tune gear ratios right?? what do you think of that idea??
Theorically can but practically u need to survey from the sifu outside. U might as well need to do some mix n match with other car make gear or even worse modify to fit it in. Its a alot alot of work to be done n to be consider !!
