Mayday! Mayday!
thugs_or_die
hi guys
my car breakdown today..need some advise..radiator's water leaking under my engine..if i fill my radiator with water...the water keep going out near the oil filter..i'm using R33 RB25DET engine..please help me here:adore:
bro, u got to chance the whole water/oil filter housing. scared might hv cracked. that's yr water/oil cooler housing. or maybe any lines loose.
some mechanic in my area said its nothing wrong with my water pump or oil filter..he said maybe the water railing...
no no...it's not the water pump or oil filter. the oil filter is mounted on the housing where yr water system also goes thru the housing to cool the oil system. i changed mine before cos a 'experienced' mech broke my oil filter housing. so had to chance a re cond housing(cost me abt 200/300 plus i thk) same time yr coolant will also need to be topped up cos all drained out.....something like a heat exchanger.
We called it Water cooled oil filter adapter.RB25DET used water cooled instead of typical Oil cooler.Check the rail/hose or adapter there,like our brother Satigue recommend!Changed da adapter if it cracked.heee
the hose got no prob..the water come out from the rail or above the rail
