Mivec Gearbox LSD
Mivec Gearbox LSD
playstation
Mivec Gearbox LSD
mivec gearbox with semi-LSD 1.5
using std dryshaft
price:
SOLD
interested call (019-2854541 hafiz)
Hi there..Got Question ..what the different between using LSD Drive Shaft and Standard one?..
Can mix ek?
Hmmm, u r trying to con people or u just really dont know about it.. but from the look of it, thats just a normal Mivec gearbox la bro..
tajulsans... i got no problem to open the gearbox n show it to u, its mivec gearbox with LSD, but if i open it infront of u n showing its LSD then u have to buy it!!! come to my workshop
kambingcool... the diffrent with drive shaft is the head shaft which is input into the gearbox, if using mivec drive shaft any problem with it then u hv to find the same drive shaft or recon it, if using std drive shaft any problem then u can just replace it with a new one or recon it
Owh Thanks for the Info..So in my situation i hav to find LSD drive shaft..
learn something today :adore:
no need to open to show qua, just plonk in the drive shaft on both side and turn, u can oledi know it is LSD or normal differential.. Heck since u r so confident with it, i'm not gonna kacau ur thread la..
bro tajul..my mivec lsd also come with standart drive shaft bro..not all lsd using diffrent type shaft..mine is semi lock too.:driver:
Bro, nice item...
Im using the same code gearbox....item is awaresome....GIGIT time cornering...make ur life not easier...hehe
If i not mistaken the ratios is 4.7 for final drive...
kakakak.. read my post carefully bro.. i'm not saying anything about drive shaft la, i know aftermarket LSD using the normal driveshaft.. Have u check the picture on the drive shaft hole where the differential is?? I guess u didnt.
well, another indirect free bump to the seller.
i've already open the gearbox to check n see whats inside, count the gear ratio for each gear..final drive n making sure its mivec n know how is lsd looks like, as for u guys (tajulsans & ber6223) like i said b4, i can open it in front of u but after that u have to buy it when its open...
Tell u why i say its not LSD, I've used the same gearbox, wit the same code & the same bloody shaft on the differential that says "this is not an LSD gearbox".. Can u catch my drift.. btw, have u pasang the drive shaft & test it or not?? There are few other method to see if a gearbox is equip wif LSD, Opening it up is so troublesome..
Wont u guys even look at the picture with shaft in the middle of the differential before saying this code have LSD, this code no LSD.
http://www.zerotohundred.com/newforums/attachments/engine-and-performance/133969d1210887731-mivec-gearbox-lsd-15052008361-jpg
hmm do u have any problem with my gearbox posting??? dont let code on the gearbox fool u... let me tell u this, i took out this gearbox frm my car, i've already use this gearbox on the road and also during drag battle at sepang so i know its lsd, wana know y coz when i bought it i also fit in my semi-lsd in it so for sure i know it has lsd, i'm selling this gearbox coz i bought a mivec full lock lsd rally spec gearbox to fit in my car preparing it for this coming drag battle at sepang 31/5...
Factory LSD models
CA4A Boxes (1991 -1994/5)
F5M22-2-????
Code:
XRZE (MD970428)
XRXE (MD971902)
XREE (MD971904)
Code:
XRWE (LSD) (MD970429)
XRGE (LSD) (MD971903)
(source: www.mivec.co.nz)
plz check first before u're calling people cheater... i also using LSD boxes, F5M222XRGE.
respect other people's post.
F5M22-2-XRWG is wat gearbox... i using it... i wan semi lsd drive shalf.
