hi nakanami, if your arm for the rear wheels with a bracket and hole. then you can use this arm. but you need to buy the connector for the bar to the arm. but i just use hard metal making it firmer..
Hi, this Mivec Anti Roll Bar...can it fit with 1.6 Bracket? or have to change.... if i change this rear Anti Roll Bar....i think have to change the front as well rite? Thx
EVO8 Bolt-on Turbo charger only (bolts to stock Evolution 6.5 through Evolution 9 exhaust manifold) with choice of GT Ball Bearing Turbo.ow flanged for Tial 44mm wastegate. Tial 44mm wastegate bolts directly to...
hi there.about to get myself an evo 8 gsr.have a few question for all u lancer owner.is it normal for an e8 gsr to have a 6 speed gearbox?and the front and rear caliper seems to be painted new.the problem here is the...
anyone stick the bitumen on the firewall, at the engine side before?what is the effect for sound proofing ?is it noticable?bcoz at 1st i tot wanna open up the dash and put bitumen+superlon...but dare not to kacau the...
