need help on air filter for 4AFE engine
keongfive
Hi all toyotarians
im planning to get myself an open pod k&n air filter for my 4AFE (auto) engine. the problem is, there seems to have an air sensor attached to the original drop in air filter box. So, if i were to remove that air sensor, what will happen? will it affect the engine or more complicated things will happen?
Need advise and help
keong
fabricate and adaptor for ur air filter that can accommodate the sensor.
do not remove it.it will effect ur engine efficiency.
go to machine shop n show ur filter n ur air box.they might know what to do.
can u show me how the air box look like?i might able to help u.i got a filter
adaptor for vios.they might be the same.
my mate replaced the RAM pipe with an aftermarket one, running with Apexi twin intake filter.
what he did was just drill a hole in the center of the ram pipe and rubber plug in the sensor. pretty straightforward from what i could see.
better have a look on the sensor first as i never actually seen a 4afe engine
before.if what u said is true,that's mean the sensor is no diff then the vtec
sensor.just drill a hole n plug it in.
Hi Sifoo GT Auto
AS promised, here are 2 pix on how the 4AFE air sensor look like... is it the same as the Vios as u mentioned?
in ur case bro,it's easy lar.u can drill a hole on a pipe n glue the sensor
to the pipe using silicone.it's not the same as vios.vios sensor use 2 screw
to secure it on the air box.
btw,hehehe...me no sifooo....me also learning.
ic... so have anyone done what im planning to do? GT, are u having the same engine as mine?
as u can see in my previous post,i never actually seen ur engine before let
alone own it...hehehe:rofl:
Not sure about you bro, but i also use 4afe engine.. i recently change to k&n open pod too.. the oxygen sensor can plug and play means no need to mod.. from what i saw was they plug out the connection only and plug to the k&n O2 sensor.. no need remove the whole sensor... hope this helps..
