P.Saga dashboard light need Help!!
Skyfiro A32
Hi bro,any1 noe how to open up the 1st gen P.saga (Taxi type) aircond control switch panel to replace all the bulb in it?my control panel currently.....all black..at the nite cant see anything...need help...thanks
If anyone doesn't reply then maybe, can give your location and sum of the ZTHians around the area should be able to help out man.. :D
I think there should have some bracket attaching to it. If you plan to diy then make sure You open it carefully. Scare you might crack the bracket though. If I'm not mistaken it's using a normal 5v Bulb. Any Advice from sifus ere.
http://undercoverproject.blogspot.com
