I have some questions here that need immediate answers...anyone with the knowledge and experience plz help!
1.Does using x1r engine oil additive increases fuel economy? or is it better to use magnetic fuel charger instead?
2.I installed voltage stabilizer in my car but without grounding wire. Is it compulsory to install grounding wire too? Will installing grounding wire increase performance?
3.What is the minimum ground clearance for decent handling. I want to lower my car's suspension to increase handling..And at the same time I do not want to risk scratching my car's bottom as the road in kuching is very bad..with bumps and potholes..so what is the ideal height for ground clearance?
4.Are there are aftermarket filter for proton tiara? I don't want to buy custom made ones as they're very expensive. My budget is around rm150.
Would appreciate if u guys can help me out with this. Thanks!
R34 carbon monitor from Duke Racing japan
