NGTC - OUTLINE TECHNICAL SPECIFICATION
Engine:
• 300+bhp 2-litre turbo-charged direct-injection engine with ‘fly by wire’ throttle control.
• Low cost to develop, build, buy and maintain – either by teams and/or race engine-builders developing their own, or through lease/purchase of the TOCA-BTCC engine
• Engine can be sourced from a manufacturers broad ‘family’ range, including subsidiary marques under their effective control.
• Over-boost function and increased power output from 2013.
Drivetrain:
• Xtrac 6 speed sequential-shift gearbox.
• AP Racing carbon clutch.
• Drive-train layout (i.e. front or rear wheel drive) as per base vehicle.
Suspension:
• Full front sub-frame incorporating suspension, brakes, transmission and engine location that attaches to specified roll cage locations. Multi-adjustable double wishbone suspension with coil-over dampers.
• Rear sub-frame that attaches to specified roll cage locations. Multi-adjustable double wishbone suspension with coil-over dampers.
Bodyshell:
• 2,3,4 or 5 door of a minimum 4.4m length. (2 or 3 door cars must share the same basic body profile as the 4/5 door model).
• Equalised width of 1875mm
• Specified front aerodynamic device incorporating flat floor, apertures for radiator, brake cooling ducts, intercooler and side exits.
• Specified rear wing profile
• Stylised front & rear wheel-arch extensions.
• Increased driver protection
• Side exhaust permitted
• 80 litre fuel tank
• Base vehicle must be freely on sale in the UK through the manufacturers normal dealer network
• Base vehicle weights, for front and rear-wheel drive, to be determined.
Wheels/Tyres:
• Specified 18” centre-lock wheel
• Dunlop: 245 x 650 x R18
Brakes:
• AP Racing specified package
• AP Racing specified pedal-box
Electronics:
• Cosworth Electronics specified package incorporating ECU, dash, data-logging and scrutineering logger.
• Data channels limited to 16.
• Common power management box and switch panels
• Common wiring loom design
Target Price:
Complete car, less engine: £100,000*
Engine: £25,000
* 5-10% price-shift possible, depending on final components used by each team
Introduction:
Eligible from 2011.
Performance parity will be maintained with current S2000 cars until 2013, after which time the performance level of the NGTC car will be increased.
