Squeaking Clutch!!!
amir123
Hello.
Im driving a manual car,perodua viva, and i am having problems with my clutch.
Usually in the morning when i drive the car, the will be no problems when i press/depress the clutch, but after i reach my destination which is about 45mins away, whenever i try to press the clutch, there will be a squeaking sound.
Does anyone know what is the problem?
This always happens whenever i travel around.
Used to happen to me when I was driving satria...weird case is that when I didn't drive it for 1-2days n the sound will gone..n comes back after sometime..has try to ask around, some said is the clutch pedal,sprayed wd40 but still nO help..somesaid is the clutch cable old d...changed before n still the same...so didn't actually bother it for quite sometime until I sold my car...now new car also having the same problem after drove for a week from dealer..sometimes got sometime no...and it didn't sound for quite sometime d till today or I too used to it until it has been automatically ignored...so my best advice is, just spray wd40, n if it does not work, then don bother it...
Ok. Thanks guys for the help. Actually i already tried spraying wd40 last time, but still the problem was there. I think ill just leave it alone.
better use grease bro....use to do this on my previous ride so far no probs after greasing...make sure u put the grease at the rite spot then there's no more squeking sound bothering u:biggrin:
