chinozie said:really aaa...
is it...really my AFM was faulty...
or i kena tipu:shocked: :shocked:
Acoustic said:i'm interested to know which category you fall under? choose from one of the below
http://www.my-acoustic.com/Car/vane_afm/warning_AFM.htm
http://www.my-acoustic.com/Car/engine_overall/sudden_bad_idle/Sudden_Bad_Idle.htm
cuscostrutbrace said:The strange thing is,my fren svt have this problem only during cold engine temp..after warm up to normal temp..problem gone,no rpm falling...but mine...still got..even worse when sometime i change gear (lift throttle and re-open throttle),the engine like die for a second and alive again,hence the choking,hesitation..pening woo..but not all the time happen like that...sometime only...the rpm falling also sometime only...let say60% it will likely to happen like that
chinozie said:the 2nd link...
but didn't changed distributor or plug...plug just do a normal check-up...
just simply changed the AFM...then idling was fine a for just a few weeks...
then wallaaaa..ECU burned...hhahahh
if i'm not mistaken the AFM is still in my garage...
do you want to take a look and test it...
P/S : sorry cuscostrutbrace for hijacking ur thread...:D
