I'm using Pioneer 5750 and all the pre-outs are used. To sub 1 is using the sub output. Now is set to 80hz on LPF, now with this coil added the voice is at minimum, without it the voice can be heard when turn to high volume
kyheng said:Well, you can try to use a 2 channel amp to power the sub without pre-amp or e-crossover. You can feel the bass abit softerand the sub moves very fast, sometimes until the voice coil disallocated. Then you try adding a coil to the sub, you can feel the bass is harder a bit and the sub movement slower.
kyheng said:The sub is not sing, only the LPF from the amp cannot filter out all the voice. That's disadvantages of using 2 channel to drive a sub without using pre-amp or e-crossover.
kyheng said:THe HU is -18. The main problem is comes from the amp, it just can't filter out all the high frequencies. Add a coil cost only rm80, but an crossover cost rm3++ What for get a crossover that only can be tuned when the car is stopped as my HU can set the fader?
