tamiya tt01 rtr
copa
1/10 Tamiya TT-01 ready to drift
INCLUDING
-adjustable camber n tie rod
-full ball bearing
-aluminium center shaft(blue)
-rear toe in
-metal motor mount
-aluminium motor heat sink
-CVA oil shocks with yellow(medium) spring front n rear
-speedmindrims + abs tyre for drifting
-Xanavi Nismo 350Z bodyshell
-few spare parts
-Manual sheet
-Both front and rear diff locked(bevel gear) both can be unlocked back easily
ELECTRONICS
-Futaba MJ (tx rx n servo) 27.095AM Mhz
-TPM8 esc (banana) limit 9T (forward n brake)
-Silvercan motor
-Side by side IB 3800Mah batery x 1
selling for rm600 nett
pm or 0173147797 copa
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
