Tire Price list Zth
Bro vr2turbo,
Would you consider toyo r1r as outdated, or do you think it still good for uhp type tyres? If got better, what would you recommend?
Toyo R1R is pretty new, but this is meant for extreme use, of course can be used for daily also.
T-1R is the road version. Latest of course is T-1Sports and many think is T-1S. No, T-1S is the older model before T-1R, so the latest is T-1Sports (asymmetric in pattern), but not sure if they have them in 15"
---------- Post added at 09:54 AM ---------- 6 hour anti-bump limit - Previous post was at 09:52 AM ----------
I'm currently using one in 15" size....need replacing soon.So just asking what's the best tires in that class (UHP, not semi slick) that I can get that's maybe superior to the Toyos. Budget taruk tepi dulu...hehe
Your 15" size is 195/50R15 or 195/55R15 and budget even though taruk must mention loh! if not how to recommend?:hmmmm::rofl:
Bro vr2turbo,
I totally respect your in depth knowledge of wheels and the tiny black rubber slab that keeps us safe on the road..
I do need your advice and suggestions on getting a new of rubbers..
I'm currently driving a Persona with stock 195/60R15 Silverstone tires..
I'm planning to get a new set of tires soon..
I'm clocking in about 40,000km annually..
Doing quite a lot of long distance travelling with some occasional spirited driving..
I need rubbers that is grippy and keep me safe on the road..
I'm currently deciding for the Michelin Pilot Sports 3 at 195/55R15..
I'm planning of a budget of about RM270 per piece..
Any suggestions for other brands/models of comparable quality??
If so, any good places to go for it??
I noticed that 195/55 is more common..
Or should I go for 195/50??
If so will the speedometer differ a lot??
At the moment the speedometer is already registering 10% faster than my actual speed based on a few GPS and smartphones..
Thank you very, very much in advance bro..
Hehe...from I what I heard, T1-R has softer sidewalls compared to R1R? So what other tires can you put into the same group as the R1R? Advan AD08? How about comparable model from Bridgestone? Hankook or Kumho? Let's say size is 195/55/R15 and budget is unlimited..lol
Extreme group wit Toyo R-1R, Yoko Advan AD-08, BS RE-11, Falken RT-615, Dunlop Star Spec Z1, Federal RS-R, GY RS Sports, Kumho Ecsta XS KU-36, Hankook RS-2 now RS-3, maybe even GT Radial Champiro SX-2 to name a few.....
The actual size you want may not have, as extreme tyres sometimes very limited sizes.....
---------- Post added at 07:54 AM ---------- 6 hour anti-bump limit - Previous post was at 07:45 AM ----------
Bro vr2turbo,
You are still on original size and your speedo already reading faster?
Regarding the tyres size, from 195/60R15, you cannot use 195/50R15 because the overall diameter is too small. More then 6% difference and will look pretty funny on your Persona.
Even 195/55R15 is smaller, slightly over 3%, but can be used. More tyre choices especially in performance category where you cannot get in 60 series aspect ratio.
For PS3 you have to check around to see whether still can get at RM270. Some mentioned 280 to even 300 now.
Other tyre in PS3 range should be Hankook V12Evo and GY F1 D5 but both are directional tyres whereas PS3 is asymmetric in pattern......Hankook and GY should be in your budget too.....
Thanks a lot for the advice bro..
In this case, care to explain what's the benefits and drawbacks of directional and asymmetric tires??
Been seeing them around for a while..
I just don't know what benefits they could bring to road users..
Directional were designed to be more effective in the wet, pushing the water to the back with straight grooves and to the side with side grooves all pointing out. Of course this is for aquaplane resistance only and grip still comes from the ribber compound. Best was the GY F1 GS-D3 model.
Asymmetric were designed for better cornering. Outer side more rubber then the inner side. Outer groove smaller then inner grooves. More rubber to outer side means more surface contact when in a corner (car leaning out). Best design to me is the Michelin PS2. The outer small groove even closes when in a corner, means outer and second row of rubber becomes one.
Having said that, with technology nowadays asymmetric pattern also becoming more efficient in the wet, due to rubber compound and thread pattern design. But as always, improvement in wet (more grooves to channel water), will get drop in dry grip (less rubber contact), therefore always choose properly according to your priorities.....:driver:
---------- Post added at 05:03 PM ---------- 6 hour anti-bump limit - Previous post was at 05:00 PM ----------
Thanks bro. Appreciate it a lot. How would you compare R1R with BS RE11? Performance and price?
Sorry, yet to try any extreme tyres......but in luck, found this for your reading......
Consumer Survey Results By Category
bro.. once i asked at apex sunway 195/50 or 55/15 for BS RE11 they quoted me RM700/pc.
*jaw dropped*
well, with wat taikor vr2turbo listed.. i gotta say dat T1R side wall much softer than R1R.
why not try Direzza Z1star. Currently on GY Eagle RS Sport.. super sticky but scary in wet.
*jaw dropped*
Yup, certain extreme tyre prices also extreme......:banghead:
Yup, tried T1-R before and sidewall is too soft for my liking too
As for most extreme tyres, especially those with less grooves the wet handling is pretty poor.
Advan AD-07, Falken RT-615, GY RS Sportsand Hankook KU-36 to name a few....
Well, I don't think I'll be driving my Persona beyond its limit that often..
Besides I've been keeping everything stock..
In this case I'll probably give the Eagle F1 the benefit of doubt..
Thanks a lot again for the advice..
I'll find out the price for it first then will have it posted here..
Is it true that all Michelin Tyres authorised dealers are not allowed to sell Michelin tyres lower than the recommended retail price?
If they are proven doing do, they may face action by Michelin company in Malaysia..
Can anyone confirm or comment on this?:damnmate:
Here are some prices for you to compare with:-
195/55R15
Bridgestone Potenza RE-001 - RM280 ED Tyres Shah Alam (Dec 11)
Bridgestone Potenza RE-002 - RM360 TMK Rawang (Dec 11)
Continental CC5 - RM210 Ukay Perdana - (Aug 11)...need to nego.
Continental CC5 - RM205 ED Tyres Shah Alam (Dec 11)
Continental CC5 - RM200 Best Drive Tmn Prima Sri Gombak inclusive B+V+Nitrogen gas (Aug 12)
Goodyear Assurance - RM200 Ban Hooi, Klang (Dec 11) include B+A+V
Goodyear F1 Directional 5 - RM250 Ban Hooi Klang (Aug11)
Goodyear F1 Directional 5 - RM279 Quicksave USJ (Sep 11)
Goodyear F1 Directional 5 - RM280 Hawk Tyres JB Jln Sri Pelangi (Dec 11) Include B+A+V+R
Goodyear F1 Directional 5 - RM260 Jazz Tires Bukit Mertajam (Feb 12) Include B+A
Hankook V12- RM230 Auto City Tyre, Shah Alam (Nov 11)
Michelin PS3 - RM290 V-care motorsport, Rawang (May 12), incl V+A+B
Michelin PS3 - RM275 Ban Hooi Klang (Dec 11)
Michelin PS3 - RM250 Hin Leong (Dec 11)
Michelin PS3 - RM275 ED Tyre Shah Alam (Dec 11)
Michelin PS3 - RM250 Speed Line Rahman Putra (Jan 12)-balancing & alignment inclusive
Michelin XM2 - RM260 ED Tyre Shah Alam (Dec 11)
Michelin XM2 - RM245 Hin Leong (Dec'11)
Michelin XM2 - RM 275 CKL Subang Jaya. (Aug 11)
Michelin XM2 - RM255 Ban Hooi Klang (Dec 11)
Michelin XM2 - RM230 Speed Line Rahman Putra (Jan 12)-balancing & alignment inclusive
Silverstone Synergy M5 - RM160 sunway Tek Ming (Aug 11)
Silverstone V7 Atlantis - RM200 Bahau including balancing (Dec 11)
Silverstone Atlantis V7 - RM190 Kim Yeow Auto, Bandar Baru Bangi, inclusive balancing (Jan 12)
Toyo Proxes R888 - RM380 TMK Rawang (Dec 11)
Toyo Proxes T1R - RM330 TMK Rawang (Dec 11)
Yokohama Advan Neova AD08 - RM470 TMK Rawang (Dec 11)
Yokohama C-Drive-2 - RM240 Kiat Mun Kajang (May 2012)
Yokohama C-Drive 2 - RM235 Tayar Tiong SEA Park (Dec 11)
Yokohama C-Drive 2 - RM210 ED Tyre Shah Alam (Dec 11)
Yokohama C-Drive 2 - RM230 Kien Hoe Yokohama USJ 19 (Sept 12)
Yokohama S Drive - RM320 TMK Rawang (Dec 11
---------- Post added at 08:31 AM ---------- 6 hour anti-bump limit - Previous post was at 08:28 AM ----------
Yup, that is what I heard also, even for BS tyres.
My friend bought before, tyre shop issue receipt they fill as selling price less trade in, even though no tyres were traded in.....:confused:
Michelin dealers also have to buy cash upfront if not mistaken.
195/55R15
Thanks for the price list bro..
Will give a few of them a call first..
I'm still split between Eagle F1 D5 and the Pilot Sport 3..
But listening to your explanation I'm kinda inclined towards the D5..
Bro., hope you did not mix them up. The directional pattern tyre that was really good in aquaplane resistance was the GY F1 GS-D3. The latest one is the F1 D5. Overall grip I think have improved, and aquaplane resistance still good but not as good as the GS-D3.
hi again,
i'm very happy with discussion that being made here about choosing tyre for my vehicle. (both city&lancer). and for now, i'm having dilemma about changing my new honda civic FD (2006). nowadays i'm using oem (205/55R16) rim&tire set, just that this month need to change for new set. i need an opinion about what type of tyre (UHP of course) and brand that should i choose. i'm a frequent travel person (penang-kl)
hi again,
205/55R16 is very common size. Here are some prices for your reference
Archilles ATR Sport - RM210 Tg Malim (Apr 12)
Bridgestone Potenza RE002 - RM495 Hup Hin Penang (Sep 11)
Bridgestone AR10 - RM350 Tmn. Daya - Next to PizzaHutDelivery (Feb 12)
Bridgestone MY01 - RM360 Tmn. Daya - Next to PizzaHutDelivery (Feb 12)
Yokohama A-drive -RM270 Tg malim (Apr 12)
Dunlop SP2000 - RM275 PJT Pusat Bandar Puchong (Aug 11)
Dunlop SP2000 - RM230 Tg Malim (Apr 12) / (Feb 12 price was $210)
Falken ZE 912 - RM290 LS tyre Genting Klang (Nov 11)
Falken ZE 912 - RM330 Bidor (Apr 12)
Falken ZE 522 - RM265 Bidor (Apr 12)
Falken ZE 522 - RM270 LS tyre Genting klang (Nov 11)
Goodyear F1 Directional 5 - RM415 Quicksave USJ (Sep 11)
Goodyear F1 Directional 5 - RM388 Quicksave (Sep 11) (include balancing & alignment exclude valve)
Goodyear F1 Directional 5 - RM370 Extreme Tyre Kuantan (Nov 11)
Hankook H437 - RM336 Bidor (Apr 12)
Hankook Ventus 12 - RM385 Bidor (Apr 12)
Hankook Ventus 12 Evo - RM305 Teck Ming Sunway (Apr 11)
Hankook Ventus 12 Evo - RM320 Teck Ming Sunway (Aug 2012, including balancing)
Hankook Ventus 12 Evo - RM380 U Tyres, Tmn. Daya (Feb 12) (Incl. alignment & balancing)
Maxxis i-Pro - RM300 Castrol Ros Merah - Opposite AmBank (Feb 12)
Michelin PS3 - RM490 LS Tyre Genting Klang (Nov 11)
Michelin PS3 - RM450 Hock Li Klang (Feb 12)
Michelin PS3 - RM520 Kee Hin OKR (Aug 12)
Michelin XM2 - RM440 Kee Hin OKR (Aug 12)
Michelin XM2 - RM470 LS Tyre Genting Klang (Nov 11)
Radar rpx900 - RM200 - Tg Malim (June 2012)
Silverstone Atlantis V7 - RM290 Tek Ming Sunway (Jan 12)
Toyo T1R - RM420 VSS Tyre Kuantan (Nov 11)
Yokohama A-Drive - RM340 Bridgstone Permas Jaya - Opposite McDonalds (Feb 12)
Yokohama C-Drive 2 - RM330 Quicksave (Oct 11)
Yokohama C Drive 2 - RM 298 DTM Sungai Buloh B+A (Jan 12)
Yokohama C.Drive 2 - RM 320 Hup Shun SS3 (Jan 12) (inc Valves & Balancing)
Yokohama C.Drive 2 - RM 290 Chin Heng, Klang (incl. valve & balancing) (Jan 12)
Yokohama C-Drive 2 - RM360 Castrol Ros Merah - Opposite AmBank
If UHP you are looking for, then Michelin PS3, Hankook V12 and GY F1D5. Check whether it fits your budget especially PS3 prices have rocketed.
One more to consider is Nexen N8000
