fabianyee,Originally posted by fabianyee@Jun 10 2004, 10:58 AM
The NMB bearing is made specifically for this purpose...
If you look at the SKF bearing which is used by Titan. there is a joint line for the housing... and the teflon layer is thick.
If the teflon layer is thick, then there is a tendency for that layer to wear off... and when that happen, the bearing would be useless...
And the NMB bearing is more expensive than the SKF bearing...
The strenght for the bearings will show when it's used on the road... It's a question of how long it can last... 1 month? 6 months? 1 year?
The result will depend on how long can the teflon layer in the bearing last....
thanks llsaw again, for taking the words outta my mouth, and made it even better.Originally posted by llsaw@Jun 10 2004, 11:45 AM
The spherical bearing in a pillowball mount is like any other "racing" part. They are designed to give optimum handling performance by limiting uni-directional flex inherent in rubber bushes towards the strut damper shaft. Noise, harshness, vibration and very high mileage longetivity are secondary. I would consider 80K km very excellent mileage for a part that most professional race/rally teams change after every few races or every season. Be it a Tein, Cusco, DMS or Titan you should really not expect the spherical bearing to last beyond 60-70K of mileage. Anyway you will only be changing the bearing itself and not the entire pillowball mount/camber plate..
ErrOriginally posted by llsaw@Jun 10 2004, 12:22 AM
Others like Ground Control will use a separate torrington or needle bearing assembly to help assist in supporting the strut but this are errm.. not cheap..
