if shift without start engine ....shld have no sound or have sound ??
it actually happened to me years back....mtf-3, motul pa90, redline were all useless at that time
only this one mechanic dare to changed my gb oil to 20W/50 mineral based engine oil and it works eversince.....
u can give it a try and it wont do any harm to your gb...
firstly, flush ur current gb oil and fill up with 20w/50 engine oil.....run for 3-4 days, flush, and fill up again...keep the routine every 5000 km
good luck!
urs got LSD?
Good question. Your gearbox is with LSD? Until now no problem at all?
urs got LSD?
currently, mine is LSD type R (Torsen LSD).... previously, on stock LSD (EG9)... I guess the LSD is ok but now having the crunching when shifting from 2-3 gear (only when high rev).... previously had replace the GB housing & the main shifter.... normal wear & tear i guess....
as per title: Type R gearbox......why on earth would i respond to this thread if i'm not using lsd.....
I'm driving an accord.....helical LSD T2W4
in terms of d blue gel,it's NOT stated anywhr dat u shudn't leave d car idle 4 more thn a week.....dis was told 2 my fren(dealer) by his supplier....prolly d supplier had had sum experience whr car being left idle not in use 4 too long d gear oil MIGHT(i'm just guessing here) harden up n turn into sludge in d gbox?d most i've tried is 2 weeks w.out using my car..so far so good......been whacking my car in SIC whnever possible,so far it has never failed me altho i know very well my synchros for 3rd & 4th gear is spoilt.....n dun worry whn u open up d gbox n ur mechanic who 4 d 1st time is seeing d blue gel will comment,"whoarr..y ur gear oil so thick like seasoned water colour 1?"...it's completely NORMAL..dat's how it protects/masks ur worn synchros......so,dun worry too much...........
YRvi,
whn did u start encountering d vibration @ high rpm problem?did any tyre work recently?could b as simple as sum mis-balancing?if not,thn u'd prolly hafta play ard w either ur drive shaft or d inner shaft-joint dat is spoilt.....easiest way i cud think of is 2 get a replacement shaft,install n c wat happens?good luck..........
Hey guys, I've got a 98 1.8T. I've had a k04 and chip for a while and wanted to get more performance. I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do...
