Up UR Rev Cut- 4G91/92/93
E-Tech
Johor
ZTHs....
Wanna up your rev?
Mitsubishi / Proton
Use to drive a Satria 1.6... ecu 5806
Even without modification the engine can actually rev higher and improve 0-100km/h, however the rev cut cut in at 6750rpm. How frustrating correct?!!
Anyway I've the learned how to overcome this and with a little fee (rm150~450), can provide you with this service....4g15 ecu 5507 , 4g91 dohc- ecu 5660 , 4g92 sohc ecu 5806 , 7472, 4g92 mivec ecu 4828 , 7305 , 4g93 sohc ecu 7781 , 4g93 dohc ecu 0450 , 5537 , 4g93t ecu 7377 , 5663 & not forgetting those using perdana wiring and ecu 6267.
e.g for 4g9x which rev cuts at 6750 can up it to 7100 / 7500 / 7750 / 8500 / 10000
For evo 1 / 2 / 3, kena sabar... still learning ecu 7701 , 2468
For vr4 - too old but have an ecu which has been chipped- ecu 8618
Currently providing service for Melaka, Tangkak & Muar, pls PM if service needed.
Honda
Since now i'm into hondas, have learned also to chipped honda ecus..
Currently have some mugen/jun/feel's chips in hand for Honda Egs..
Mainly Ecu code P30/P08.
AT to MT ecu modification can also be done (trouble code 19)
Pls PM if service is require... Thanks for reading.
bro...
10K sure ur car can?
Must make sure your engine do balancing first lor...
and at least must have safc for fuel tuning..
Rm300
tq
Bro, 4g15, 5507
currently rev kosong limit at 7K rpm, when drive, limit at 7150rpm (i think, because the jarum lebih sikit je from 7..). before this using carb, can go up to 8K rpm (then no more number..). can tune make it 8-9K rpm? how much? thx
Bro..kwn use 4G93SOHC boleh tukar ke DOHC setting ke?
Muhadali...
Ur Q i cannot understand....
U want to use 4G93dohc ecu? or u want to use 4g93dohc power transistor and distributor?:confused:
Like this bro..I have ECU 4G93 SOHC, can U remap the programe to DOHC setting?
