VR4 piston + ring (ART) New - RM 650
My contact 016-5040890Best possible is give me ur current piston and then I tell you which size available ex-stok at my supplier place. Too many sizes ler......
awesom thanx for the contact num,i'll call u but for sure i'm looking for 86.5 or 87.0mm
Yeah I need ur piston to measure bro......
alucar:
possible to get me u current one? sample is the best way to match and can tell you later wat options you have.
Boss HMS... kinda difficult as the piston is still in the car!! :/
Bore is 81mm, Stroke is 89mm. Its the standard 4G93T piston. Let me see if there are some condemn ones lying around at my mechs, but I doubt so. How ar?
I try to check and see got how many models first? Standard i will oso check.
GSR turbo right?
Yes, its for a turbo compression ratio is 8.5 : 1
Thanks
I have a std Evo 1 and I have done some balancing. Can I get lower compression piston to run at higher boost?
If I just want std replacement ring set how much would it cost me ?
My engine is already open and I hope to change it before I fix them again.
Thanks in advance
Watever that u are looking for the best is giv me the sample then i can advise wat options u can choose from. Gif me a call or sms me.
Kum 016-5040890
Thanks in advance
