waja ignition coil burnt! why?
ahren
hey guys, after BOT for 2 months, problem arised again.
For your information waja have 2 ignition coil which connected to the spark plug. My car was having dificulty to start after long run in highway and get diagnosed that 1 side of the ignition coil malfunction. Today my car have the same problem again, and the foreman told me the same side of the ignition coil spoilt.
He suspect is the turbo causing the ignition coil malfunction. Anyone have any idea what is it going on? Could it be the tuning problem? or engine over heated problem?
thanks alot!:_:
Which side of the coil is burn eg primary or secondary coil?
The mechanic should be able to fix this problem. I suspect that the coil is turn ON for too long. In order to generate a spark, those coil need to be ON and OFF repeatedly at a fast rate.
Btw, this is not the correct thread you should post.
thanks for the reply.
Mod pls help to move my thread to the correct category :)
proton maaa...............there has been many incidences of Waja catching fire, search the forum and you will find a few thread about it.
