Hi everybody, i juzt wonder is there any WALBRO fuel pump larger than 255lph-hp? and is it when the pump is working, there will b a loud sound produce from the pump?
i'm using Walbro 255 LPH, the sound aar, how can i define here by words?? suggest u go listen to one which have installed, i'm staying in penang and ur in butterworth, if u can get a trip up to northern garage u can listen to my fuel pump....
Thank you simple guy. The FPR set how many Psi? I use Arospeed FPR. Boleh pakai kah? And actually how FPR helps Mivec or any other engine in terms of performance?
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not...
salam MLOC (sory xreti speakang sikit2 je tau)..aku ejad, stay putrajaya, baru pakai evo9.. so xberape tau sgt info2 evo ni.. ade benda skit aku nak tanya la..plz...
