Thank you so much bro, you give me all the answers I need! Just to confirm 1 more time, Nismo oil pump is made of SCM430H Gear?
So from your suggestion for 450awhp+-, is worth to get a N1 oil pump(with SCM430H Gear modified) or 1 shot buy Nismo oil pump? And is the crank collar required to used?
Yup same material for NISMO gear.....It`s up to your need bro, NISMO Oil pump is 2 times expensive compare to N1 pump and almost same price wth high end pump (JUN/HKS) ....
converting the N1 also will ended same price wth NISMO oil pump.
If you looking at 450HP within
For serious sports/race driving or durability term beyond >8000RPM Redline
with minimal modifying, then get the NISMO Oil pump. But you will have a LIMIT there.
Collar not necessary for R34 (or Model above BNR32 Kouki VSpec)
...now..it's time to thank for a good work done by Kit and his crew...Well, I have to...
